H hudsons1 Reputable May 26, 2015 1 0 4,510 May 26, 2015 #1 I have a Jambox wireless Bluetooth speaker. I want to be able to play the music channel on my TV through this, but my TV is not Bluetooth capable. What is the adapter that I will need?
Solution A A americanaudiophile May 28, 2015 If your TV only has optical audio out then you would need a transmitter like this one http://www.telme2.com/webshop/index.php?id_product=8&controller=product If your TV has analog audio out or headphone out you can use one like this http://www.amazon.com/Miccus-Home-RTX-Bluetooth-Transmitter/dp/B00713RSE0/ref=sr_1_6?ie=UTF8&qid=1394218482&sr=8-6&keywords=bluetooth+adapter+for+tv If you use a headphone out you will have to adjust the TV volume so it doesn't overload the transmitter. It will also cut off the built in TV speaker when you plug it in.
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 May 28, 2015 #2 Look for a 3.5mm to Bluetooth adapter, and plug that into the TV's headphone output. Many of them in different sites, Amazon, eBay, Newegg, etc.. Upvote 0 Downvote
A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 May 28, 2015 #3 This adapter should be labeled "Bluetooth transmitter" (since "BT receiver" are much more common, and they work other way around). Upvote 0 Downvote
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 May 28, 2015 Solution #4 If your TV only has optical audio out then you would need a transmitter like this one http://www.telme2.com/webshop/index.php?id_product=8&controller=product If your TV has analog audio out or headphone out you can use one like this http://www.amazon.com/Miccus-Home-RTX-Bluetooth-Transmitter/dp/B00713RSE0/ref=sr_1_6?ie=UTF8&qid=1394218482&sr=8-6&keywords=bluetooth+adapter+for+tv If you use a headphone out you will have to adjust the TV volume so it doesn't overload the transmitter. It will also cut off the built in TV speaker when you plug it in. Upvote 0 Downvote Solution
