Wireless card HELP!!!
techy123
Hi everyone I could use some help here.
My laptop is an Hp Probook 4530s. I decided that I would upgrade the wireless card to an 802.11 AC card.
So I purchased a Intel 7260 dual AC card.
When I replaced it in the motherboard I get a BIOS message saying the hardware is not compatible. And the system will shut the card off. Though when I boot to the OS the device driver for the Bluetooth in the card installs. Could anyone tell me if I did something wrong to make this not work?
Or if it is definitely not compatible with my system what card could I upgrade it with?
http://www.amazon.com/Bplus-7260-HMWG-Wireless-AC-Bluetooth-HMCPartner/dp/B00HJCBV64
is this the one? if so
"For those that may not know; if you receive an error at start-up after install, this means your laptops manufacture has blocked the card from working (Only approved cards). You will need to re-flash your laptops bios/firmware with a modified version that remove this 'blocking' function. (white listed)"
from the description "Please know that this card is the universal version, it will work on all the laptops except Thinkpads/ Lenovo and HP For half size mini pci-e slot, Not for IBM Lenovo and HP machines."
if I was helpful I could care less about the downvote.
