Hi. I'm having problem in sharing a printer with wireless connection from end user.
I have PC1, PC2 and a L360 Printer. L360 Printer is not capable in wireless connection.
So what I did, L360 printer is connected to PC1 via USB Printer Cable connection and the PC1 itself having a LAN Cable connected to the ROUTER.
While PC2 is having a wireless connection to the ROUTER.
I've done all the sharing setup in PC1 and PC2. PC2 already detected the printer from PC1 but when I tried to do the TEST PRINT from PC2 it will show a CONNECTION ERROR.
Does the L360 printer has its own IP address? bcause I wanna try to manually connect using the IP address of printer from PC2.
And where do I find the IP address of the printer?
Hope you can help me. Thanks
