[SOLVED] Wireless display ?
Hi all i was wandering if there was any like hdmi transceiver to hdmi transceiver kit that allows for wireless display? Instead of having to have a cable for a "learning to crawl" toddler to mess about with I'm going to make the living room streaming PC as wireless as possible. I removed ethernet, wired keyboard, mouse & speakers so now have wireless everything except the display. However, I'm not sure what or how a wireless display cable adapter thing would be labelled exactly, if it even exists ?
There are such products.
And a bit costly.
For example:
https://www.amazon.com/Actiontec-Wi...M?tag=imoreb-20&ascsubtag=UUimUdUnU72346YYwYg
May prove more problematic because you need electrical at both ends (TX and RX) and a couple of extra cables. Placement can be awkward as well.
Visit the manufacturer's website to find and read the applicable User Manuals. May help you decide about options and installation.
Again, for example:
https://www.actiontec.com/wp-content/uploads/2017/01/MWTV2-Installation_Guide.pdf
And a bit costly.
For example:
Again, for example:
Reactions: white.a.drew
And a bit costly.
For example:
Again, for example:
okay thank you i'll just stick with a wired display then because that basically brings back all the wires i just got rid if ha.
