[SOLVED] Wireless Earbuds become choppy when i use both earbuds
Nov 17, 2021
53
Hi, so I recently bought these "S68" earbuds, and the audio is great when i just use the right (primary) earbud, but when i use the other one, the audio instantly becomes choppy and randomly cuts off. Any solutions?
Test the earbuds on the current host system with no other Bluetooth devices connected and enabled.
If the problems end then enable other Bluetooth devices one at a time (allow time between additions) to discover a possible conflict.
Failing that:
Try the earbuds on another known working system.
If possible try other known working (no choppiness and/or random cutoffs) earbuds on your system.
Determine if the problem follows the earbuds or stays with the current host system.
Overall, my thought is that the earbuds may simply be defective in some manner of design, components, assembly, etc...
Unless the earbuds can be shown to properly work in some functional environment then the earbuds should be returned for a replacement set...
Failing that:
Unless the earbuds can be shown to properly work in some functional environment then the earbuds should be returned for a replacement set or a refund.
