Wireless headphones for model EH500F TV
Orobert73
Can i use wireless headphones for samsung tv model number un50eh500f?
If can is there a cheap brand around $30 you can recommend?
it looks like your tv supports a headphone jack (check your tv to verify) which would mean yes as wireless headphones for tv use generally connect via 3.5mm which goes to the wireless transmitter..
there are cheap models under $30 you could use but none that i could personally give a recommendation on.
