Wireless home network and bandwidth management problems.
FievelGoesPostal
35
So after a few years of trouble on Comcasts end, they switched out my modem for a wireless modem/gateway. I had previously been using an Asus RT N65U, and was able to manage my bandwidth via the router control panel.
After building my brother a PC last night and getting him connected to my network, I find that whenever he downloads anything it sucks up all the bandwidth on the network completely. Another problem entirely, but even when his wireless card was only getting 5mbs and d/l at 300k ( every other PC d/ls at over 3mb) it was still sucking up all the bandwidth. Nearly impossible to even browse the web on any other pc.
The problem is Comcasts gateway control panel has no way to manage bandwidth. I would like to be able to shut off the Comcast gateway's wireless ability and just use it as a modem with my Asus router providing the wireless , but that doesnt seem to be possible. At the moment, I have the Asus router connected to the Comcast gateway via ethernet. While any device I have can connect to the Asus network, it will only provide internet access to 1 device at a time.
Any thing I can do? Or do I just need to switch out the Comcast gateway for a regular modem and go back to my router? Thanks!
Although not the optimum setup when you need to port forward and such you can run router behind a router and it should work fine.
You should be able to put your asus behind the comcast router and run it just as before. You will of course need to make sure the wan and lan subnets do not conflict. You would turn off the wireless on the comcast...you could leave it on if you were careful traffic since the asus has no knowledge of users on that side of the router.
It is strange that you can not set the device to bridge only mode but there are some modem/routers that do not support that for some reason.
FievelGoesPostal
35
Thanks for the reply. This gives me some direction. My Comcast gateway has no way for me to shut off the wireless and put it in bridge mode. After doing some research, it looks like I can contact Comcast and have them do it
