I have a mobile home with steel roof,and sides.I need wireless internet ....i live in a rural area.The main tower is less than 1/4 mile away.I intend to hard wire the computer from the antenna mounted on the roof,,,,,,,,(if that is possable)
Can you tell me how to install a wi fi antenna on a steel roof so i can wire it directly to my desktop?
I had a cable provider to my home,and they got really good signal,but it was bouncy,and noise.They told me to contact them after the leaves were out....and they left. (dunno)
Anyway......Is there a way possable to get an antenna on the roof to get a strong clear signal,...there must be! Would a very long antenna post do the trick? Would coating my roof with roof coating do it?..I really need this internet,,please help.Any advice would be great!
Thanks!
Thanks!
