Wireless IntelliMouse Explorer and PS/2
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I am trying to use my Wireless IntelliMouse Explorer with IOGear KVM
switch and the XP Home PC does not seem to recognize the mouse when it
is plugged in the PS/2. Of course it sees it when it is plugged in as
USB.
If it helps, USB the light turns on the wireless unit, but not when
plugged in PS/2.
Any help would be great!
Thanks.
On KVM switches, the PS/2 ports have "passive" power. The switch only
maintain "connection" with the PC. As for USB, it provides active power.
"craig cappel" <craigcapello@yahoo.com> wrote in message
news:1fbd1e5f.0410111636.78cba936@posting.google.com...
> Hi,
> USB.
> plugged in PS/2.
> Thanks.
First thing I would do is check your Bios to make sure PS2 is enabled.
> Hi,
> USB.
> plugged in PS/2.
> Thanks.
