wireless mouse wont work
May 4, 2018
I have two laptops and use A Logitech wireless mouse that use to work with both but since I did A reset with one it does not work, the one that does work says it has Hid-compliant mouse the one that does not work does not I am thinking that when I did A reset of windows 10 it took away the ability to use the wireless mouse
No drivers I believe the problem is the PC does not detect the little receiver which comes with the wireless mouse when I plug in the other PC the mouse works when I opened device manager and scroll down to mouse it shows hid-compliant mouse detected on the other PC there is no hid-compliant detection added that's the problem I feel and don't know how to get it back
