I built my own computer and decided to connect it wirelessly, I picked this adapter
TP-LINK TL-WN725N Wireless N Nano USB Adapter, 150Mbps
http://www.amazon.ca/TP-LINK-TL-WN725N-Wireless-Adapter-Miniature/dp/B008IFXQFU/ref=pd_rhf_dp_p_img_1
My router is a Linsys WRT54G.
I can connect to the router using the adapter but the problem is this: http://www.speedtest.net/my-result/4002659802
Everytime I start up my computer, the download speed is fine but after like 5 minutes it goes down but the upload speed is fine.. The download speed should be about 10Mbps as it is on any other device I try in the same room I have another computer using a TP-Link TL-WN851ND Wireless N300 PCI Adapter, 300 Mbps that connects perfectly.
(http://www.amazon.ca/TP-Link-TL-WN851ND-Wireless-Adapter-Support/dp/B005NHIQ06/ref=sr_1_1?ie=UTF8&qid=1419012438&sr=8-1&keywords=tl+wn851nd)
I contact TP-LINK support but there is nothing they can do.
I think the adapter is the problem as any other device works perfectly fine so I thought of buying TP-Link TL-WN881ND Wireless N300 PCI Express Adapter, 300 Mbps, WPS Button, 802.1b/g/n, Support 64/128 Bit WEP, WEP, WPA/WPA2 because my computer only has a PCI Express slot available and because the outside antenna might help connect to the router.
(http://www.amazon.ca/TP-Link-TL-WN881ND-Wireless-Express-Adapter/dp/B0079XWMEI/ref=pd_sim_sbs_pc_1?ie=UTF8&refRID=060JC34RZ4Y2JWHDK219)
