Wireless Network Adapter compatible with ASROCK H97 PRO4
veteran73
12
Hey guys...Finishing up a pc build and trying to find an adapter that supports Windows 8.1 and compatible with the PRO4. Im in pc part picker, cant seem to find one. Need help please!!! Cost really no problem. Thanks.
With the drivers provided any wireless adapter will work with your motherboard. I have never seen a wireless adapter that listed the motherboards it was compatible with. If the adapter lists it has Windows 8 drivers it will work.
Hi lantrich...when I find a wireless adapter that supports 8.1 in google, pc part picker doesnt show that item compatible with PRO4. Thats where Im stuck. Hope it makes sense. I dont know if this matter, but my system is for 3d modeling/rendering, no gaming or anything like that. Thanks.
Probably because all wireless adapters are compatible. It makes no difference what you are using it to do the adapter just makes your computer accessible to the internet. The newer the protocol the faster your internet speed depending on what speed your ISP provides.
Yeah thats cool. Next stop ASROCK website. Im so close to being done, dont want anymore set backs. I may just stay with Windows 7, wanted to try out 8.1. Havent installed either one yet. Thanks for the help.
