U Unforgettable98 Reputable Dec 27, 2014 82 0 4,630 Jan 10, 2015 #1 So I've almost got my pc built. I'm not going to be connected through ethernet (wired). I need a good wireless network adapter for $20 or under. Also what is the difference in a USB one and an antenna one?
Solution Barney6262 Jan 10, 2015 Hi, as always I will say wireless is not only A LOT slower than ethernet but will also cause more issues. If you still need to use wireless any PCI wireless card should be sufficient, have a look at customer reviews to see if they are reliable. Some suggestions: IF you have a dual band router: http://www.newegg.com/Product/Product.aspx?Item=33-704-133&Tpk=N82E16833704133
Barney6262 Honorable Oct 20, 2013 989 0 11,360 Jan 10, 2015 Solution #2 Hi, as always I will say wireless is not only A LOT slower than ethernet but will also cause more issues. If you still need to use wireless any PCI wireless card should be sufficient, have a look at customer reviews to see if they are reliable. Some suggestions: IF you have a dual band router: http://www.newegg.com/Product/Product.aspx?Item=33-704-133&Tpk=N82E16833704133 Upvote 0 Downvote Solution
