Wireless or Direct connection
Rudder
What is best for the fastest internet connection Wireless or Direct connection and how many feet can you run a Cat 5 cable? Also can a TV cable be converted to a cat 5 cable?
You can convert the signal for Cable TV to ethernet based signal using a digital cable tuner, Windows Media Center and extenders. It would require creating an HTPC, purchasing a digital cable tuner, and using XBox 360/Ceton Echos for displaying the signal on the remote TVs.
Off subject but you are the man when it comes to all things media center.
