Wireless primary workstation pc monitor
Skanthb
9
Hi All,
I'm buying components to build a new workstation:
Configuration:
Motherboard: SUPERMICRO MBD-X10DAI-O Extended ATX Dual LGA 2011 Intel C612 Xeon Workstation Motherboard
Processor: Intel Xeon E5-2620 v3 Haswell 2.4GHz (3.2GHz TB) 85W 15MB L3 Cache 6 Core (12 Cores Total)
Hard Drive: Western Digital Caviar Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
Memory: 16GB (4 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4-17000) ECC Server Memory
Power Supply: 850W - Rosewill Xtreme Series 850W Continuous @40°C 80 PLUS Certified Power Supply
Video: NVIDIA Quadro K620 2GB 128-bit DDR3 PCI Express 2.0 x16 Workstation Video Card
Case: Phanteks “ Enthoo Pro Series “ PH-ES614P_BK Black Steel / Plastic ATX Full Tower Computer Case
the one last thing i have to buy is a monitor. Can someone help me with some wireless portable options .. economical off-course.
Can i buy some tablet like monitor and connect to the tower directly as primary one (without any connected monitor at all)?
Thanks,
Srikanth
