[SOLVED] Wireless print from android phone
parsserver.in
4
Hey guys.
I have d-link DSL-2770L and samsung multi function printer SCX-4521F connected to each other using USB cable.
My router has wireless print server with usb. For windows, It needs a software named Link'n Print. I can print from my laptop wirelessly. But in my android phone (samsung galaxy A6) i can't.
Is there any way to find same printer that connected to router in android os? Android phone connected to same wireless but print function does not work.
Please let me know if you had same problem and solved it. It will help me alot. Thanks regard.
And finally sory for bad english.
There is no Link'n Print app on the android play store. Can you try the Samsung Mobile Print app and see if that will work.
Mine never worked well for me but my router and printer were both older then yours.
