Wireless Printer connect to Wired PC
Jumpah
7
My PC is connected via Ethernet and I have a printer that I need to hook up to my PC, but the thing is, my PC doesn't support WiFi. Know I can get a wireless adapter for my PC, but I don't want to do that bc I'm lazy. Is there another way to connect my wireless printer to my wired PC? Thanks.
If you already have a wireless router or access point then you just need to enable the Wifi on that, and it will connect right through the existing wire after you enter the SSID and key into the printer. That's what it's for.
PC talks to the router.
Printer talks to the same router via WiFi.
Done.
