Archived from groups: alt.internet.wireless,comp.periphs.printers (More info?)
Im thinking of buying a printer and due to the size and location I would
like the printer to be upstairs and
connect to it wirelessly.
So how do I make it wireless ? The options :
A) The printer has an Ethernet port but no wifi... should I buy a print
server ?
B) Should I buy an Ethernet bridge to make it into 802.11g compatible ?
C) The 3rd option is a wifi router - could I buy a router and have a small
ethernet cable hooked into it and then access
the printer through the router wirelessley ? This way the router is alot
better equipment and does the same thing as an Ethernet bridge / print
server.
Which is the best and space saving ?
Thanks.
server ?
server.
Thanks.
