Wireless Printing
minners
5
Hello, I currently have a printer setup on a desktop computer as a network printer. I can access the printer fine from my laptop via my wireless network and windows 7 home group although of course I have to have the desktop machine turned on and connected to the wireless network.
I would like to make the printer wireless so that it can be accessed directly. I have a spare netgear router, can that be configured to allow the printer to connect to my existing wireless network? The printer is in the upstairs office of the house, the internet router (virgin superhub) is downstairs.
If this is possible how to I go about doing it?
Thanks
Ok many thanks, it was just an idea. Do you know of a suitable router that I may be able to pick up reasonably on ebay?
Thanks.
most routers will need a third party firmware.
here is the link to the DD-WRT database where you can look up if the router of your choice is compatible with there firmware.
http://www.ebay.co.uk/sch/i.html?_trksid=m570.l3201&_nkw=asus+rt-n12&_sacat=0
you could also look at extender/bridges but they are usually more expensive.
most ASUS, Linksys (not starting with EA), Netgear, D-Link DIR-615 will work with DD-WRT. Most of the newest routers are not supported yet
