Wireless Repeater HELP! Please
arabanipark
Hey guys,
I have bought a Winstar WN518N2 Wireless N Wi-Fi Repeater a few days ago and its giving me a major headache trying to set it up.
In the installation guide (which is very poorly explained), its telling me to setup a manual TCP/IPv4 connection on my computer.
This is exactly what it is being said:
Plug your computer with the Wifi Repeater with RJ45 cable. Type Ip address is 192.168.10.x (x is from 2 to 254). Subnet mask is 255.255.255.0. Type routers LAN IP address (the default IP is 192.168.10.1) into the default gateway field.
Open web browser and type 192.168.10.1 and the login screen will appear.
I have tried that and when I go in my browser and type 192.168.10.1, i get an endless loop turning and at one point it tells me that the webpage cannot be displayed.
This is the configuration I tried:
Ip Address: 192.168.10.2
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.10.1
On the backside of the repeater, there is also another ip address mentioned, 192.168.0.1.
So I have tried setting up my IPv4 with something like:
Ip Address: 192.168.0.2
Default Gateway: 192.168.0.1
That also did not work.
My main router is a Dlink and has DHCP setup as 192.168.0.3 to 192.168.0.50
Im completely out of ideas and in need of help...
Thank you
If you've tried setting your PC's network adapter to those values, and it doesn't work, you might also need to adjust the DNS values for the network adapter. It seems like whatever is written on the range extender itself is more likely correct, but it would collide with your router's DHCP settings. So you may need to clear your browser cache, change your router's DHCP range to something like 10.0.0.x, check your PC's host file for localhost at conflicting addresses, and/or make sure a loopback adapter isn't causing the browser problem.
vmfantom
Notable
Nov 28, 2017
181
