You are looking a a budget router that is based on the minimal spec. If you want an improvement get a better router. You have not mentioned much in terms of what you are doing, wireless devices, wire connections, bandwidth speeds etc. But in todays world you want a dual band router that is at least an N600 which means ist 300mbs in both the 2.4 and 5ghz bands. This is really the minimum spec for most client devices today.
Look at something like a Netgear WNDR3400 as the minimum spec today. A lot has changed n router technology. The 3400 to me a good basic entry point. Amazon has refurbs of these for about $40.
Bob Silver
Netgear Network Assistant
