Wireless Subwoofer and reciever
Lulaz
Hello there!
First of all, I`m new here into this forum and I did not find the "search" button fors searchs inside the forum, that is the reason I`m posting here.
Well, I`m looking to buy a new 5.1 sound sistem, of course, with a subwoofer and 5 speakers.
I got one 5.1 already, but I have problems with the number of cables and the fact that it is old and have lots of interference (from other power cables)...
Plus I got a TV, Computer and a xbox that I want to plug all into one sistem (subwoofer).
I want to buy a wireless sistem (it doens`t matter the power source, only the audio cables I`m concerned about) and maybe a reciver to center all tv, xbox and computer in only 1 place.
My budget is about $150 on the sub (a bit more if needed, for a wireless sistem) and no clue for the reciever (actually I just start to look for it right now).
It doesn`t has to be a super sistem or reciever, because it is only for my bedroom, not for my livinroom.
Thank you for the help!
it sounds to me like you have very thin budget . maybe you would be better off saving up for a while as $150 won't get you a whole even on ebay or at your local pawn shop .
if you do happen to come out smelling like rose let us know what you found!
