Wireless USB Adapter Ridiculously Slow After Reformat (Upload Seems Okay)
TobyTheRobot
Commendable
Apr 30, 2017
7
My system has two network adapters. One is a PCI Qualcomm Atheros AR9485 Wireless Network Adapter. The other is an Edimax AC1750 USB Network Adapter, which I bought for 5GhZ band support after a router upgrade. It had always worked perfectly.
I just bought/installed a swanky new Samsung SSD, and I reformatted the old drive and reinstalled Windows 10 on the new one. I've run windows update until there's no further updates and everything seems to be working fine except the Edimax adapter. I did a speedtest and the download speed is around 0.25 MBPS (before the reformat it was around 90). Strangely, upload speeds are around 45-50, as they always were.
I've taken the following troubleshooting steps already:
-I tried using the Edimax adapter on my laptop. Seems to work perfectly, so it's definitely not the adapter.
-I tried switching the Edimax adapter to different USB ports on the reformatted system. Same result every time, so it's not a bad port.
-I tried disabling the Qualcomm adapter in the device manager just in case there was a conflict/interference or something. Didn't work, and the USB adapter worked perfectly before the reformat anyway.
-I switched back to the Qualcomm adapter on my reformatted system. Seems to work okay, albeit without 5 GhZ support.
I'm kind of at my wit's end here -- I figure it's probably something with the USB on the reformatted system, as the adapter is plug-and-play. Can anyone help?
What drivers are you using? Try looking up your model number in wikidevi.com and find the chipset it uses. Then search for drivers for that chipset...not necessarily by Edimax. I have done this for both a Netgear AC1200 USB that was on an old laptop and an ASUS PCI-e adapter that I'm using now. With the manufacturer drivers I was very disappointed. When I found generic chipset drivers by the chipset manufacturer both times have resulted in full performance. Not saying this will solve your problem but definitely worth troubleshooting with.
They are probably interfering with each other. It doesn't matter that they are on different frequencies. The strongest radio signal wins. See the following article and you'll understand why it's a terrible idea to put two WiFi transceivers next to each other.
https://arstechnica.com/information-technology/2017/03/802-eleventy-what-a-deep-dive-into-why-wi-fi-kind-of-sucks/
Scroll down to "A tale of two problems: Signal, and interference". You might want to go back to the top and read the whole article.
Thanks for the answer, but I think this is unlikely to be the case simply because the UBS adapter worked perfectly before the reformat. It seems much more likely to be a software issue.
I've tried that. It didn't work. (I'll update the post to reflect this.)
