Wireless USB connection stopped connecting
jaster
142
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Anyone have an idea to troubleshoot this problem?
Friend's pc using Netgear USB nic (ma111) stopped connecting with the
Netgear wireless router. Other pcs with a wireless connection to the
router work. This pc's nic is working properly according to WinMe, WEP
encrytion is enabled, pass code is correct but the pc still doesn't
connect to the router to obtain a DHCP address or by using a static ip
address. This WinMe pc was working properly but it stopped connecting
over the weekend.
TIA
I just had a wireless USB key like Netgear's die on me, exhibiting the same
symptoms. It worked fine, then stopped connecting. The computer still
shows
it as ok and I can still access the options. Part of it fried, I guess.
Try connecting
it to other computers, then return it if it works on none.
Dave
"jaster" <jaster@home.net> wrote in message
news😛an.2004.05.27.23.07.00.871440@home.net...
> over the weekend.
> TIA
>over the weekend.
>TIA
USB + networking spells Trouble.
Many USB items only work on the first port they were installed on.
Plugging into another slot on the same box will not work unless setup
is run again.
Fight back!
http://tinyurl.com/hhez
> shows
> Try connecting
> Dave
Dave thanks. I didn't think the NIC would have failed within 3-4
months. I don't know if trying the NIC on another machine was done
yet.
>> over the weekend.
>> TIA
