Wireless wifi usb card horrid.
snowboarde1010
25
Hello
I have recently bought a new pc but the internet on it is just horrid. The upload speed is below one mb when it should be at least 40. The upload is below 10 when it should be 50. The ping is 9, which is fine. Sometimes, both upload and download or below 1mb and ping is 300+. Other times the connection is amazing. Someone please help me with this, here are my wireless card specs.
My card - Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter
my speed right now http://www.speedtest.net/result/4940455530.png
how it should be ( on every other device & same room as pc) http://www.speedtest.net/my-result/i/1474368534
Please help. Thanks!
(This information is from speccy)
Network
You are connected to the internet
Connected through Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter
IP Address 192.168.1.17
Subnet mask 255.255.255.0
Gateway server 192.168.1.1
Preferred DNS server 192.168.1.1
DHCP Enabled
DHCP server 192.168.1.1
External IP Address 173.74.170.66
Adapter Type IEEE 802.11 wireless
NetBIOS over TCP/IP Enabled via DHCP
NETBIOS Node Type Hybrid node
Link Speed 1.2 MBps
Computer Name
NetBIOS Name DESKTOP-2B93PTF
DNS Name DESKTOP-2B93PTF
Membership Part of workgroup
Workgroup WORKGROUP
Remote Desktop
Disabled
Console
State Active
Domain DESKTOP-2B93PTF
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Using native Wi-Fi API version 2
Available access points count 1
Wi-Fi (SFVQ7)
SSID SFVQ7
Frequency 2437000 kHz
Channel Number 6
Name SFVQ7
Signal Strength/Quality 88
Security Enabled
State The interface is connected to a network
Dot11 Type Infrastructure BSS network
Network Connectible
Network Flags Currently Connected to this network
Cipher Algorithm to be used when joining this network AES-CCMP algorithm
Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout (ms) 60,000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout (ms) 30,000
IEProxy Auto Detect Yes
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Sharing and Discovery
Network Discovery Disabled
File and Printer Sharing Disabled
File and printer sharing service Enabled
Simple File Sharing Enabled
Administrative Shares Enabled
Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
Adapters List
Enabled
Realtek PCIe GBE Family Controller
Connection Name Ethernet
DHCP enabled Yes
MAC Address D8-CB-8A-C7-CA-2E
Connection-specific DNS Suffix home
Connection Name Wi-Fi
NetBIOS over TCPIP Yes
DHCP enabled Yes
MAC Address 74-DA-38-63-9D-E3
DHCP 192.168.1.1
DNS Server 192.168.1.1
Network Shares
No network shares
Current TCP Connections
AppleMobileDeviceService.exe (2060)
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7404)
C:\Program Files (x86)\i-Funbox DevTeam\iFunBox_x64.exe (1324)
C:\Program Files (x86)\Skype\Phone\Skype.exe (2692)
C:\Program Files (x86)\Steam\Steam.exe (8016)
C:\Program Files\iTunes\iTunesHelper.exe (4104)
C:\Windows\explorer.exe (3468)
lsass.exe (820)
mDNSResponder.exe (2540)
NvNetworkService.exe (2284)
NvStreamNetworkService.exe (3028)
NvStreamService.exe (2304)
services.exe (808)
spoolsv.exe (1924)
svchost.exe (1188)
svchost.exe (340)
svchost.exe (960)
System Process
System Process
wininit.exe (696)
Go to Control Panel>Device Manager>Network Adapters then right click on your wireless adapter and select Properties. Go to the advanced tab and under Wireless Mode, try each one and check your speed test to see if one drastically improves your speed. Also look into changing the channel on your wireless router, your current channel may be congested.
http://www.pcadvisor.co.uk/how-to/network-wifi/how-change-wi-fi-channel-3325316/
