My wireless works fantastically, without any problems, but my wired connection doesn't.
After a system startup, the wired connection seems to either work for a couple minutes and then take a dump and isn't able to identify the network, OR it just isn't able to identify the network intially after starting up. It's possible that the new powerline adapter I'm using to connect to the router/gateway is messing something up, but as far as its instructions go, all of the symptoms of it working the way it should are showing. I've tried reinstalling the network adapter software, editing the network adapter settings (in network & sharing center -> change adapter settings -> local area connection -> Propterties -> Configure -> Advanced) and wasn't too sure of what any of those did, so a little help there would be nice.
I can't exactly do anything physically to the router as of my situation right now or access the host computer that has the network setup.
I'd say the main problem right now is that the wired connection has problems identifying the network, and fails to keep a connection for extended periods of time.
