So pretty much heres whats going on, or atleast what I'm finding really weird. There are 2 fans in the case, the cpu fan, and a fan in the videocard. one fan in the case and the cpu fan is connected to the motherboard, the other case fan is connected directly to the power source and the videocard is also connected directly to the power source. Now when I turn off the computer all of the fans still run (from the power button). I notice the videocard fan in particular is really loud. the light on the motherboard also is on even though the power key is off (although i think this is this normal) Now it is very difficult to turn on the computer.
EDIT: I just noticed power is not making it to the usb output when the power switches are on...
It takes many times repeating turning off and on the power switch and button to make it work. EDIT: i don't know how i got it to work last time, it's not working now... When the comp is on it works perfectly... I am very confused at what the problem could be. Happy to answer any questions.
Heres my build:
CORSAIR 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMV8GX3M2A1333C9
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233192
SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102948
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103808
Antec High Current Gamer Series HCG-620 620W ATX12V v2.3 / EPS12V v2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817371048
Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136794
ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131767
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119233
and 64-bit windows 7 + a dvd burner..
If this is in the wrong forum please let me know where it should be posted.
Thx
Heres my build:
Thx
