So, like anyone else i have problems with wifi signal strengh.So situation is that im renting a room, where im living, and renter's router is put near the doors, so wifi signal in my room is about 2 from 4,routers signal comes thru 2 walls. Then goes another problem: with my brothers laptop i used to play League of Legends and it worked fine, but i have desktop pc, so i was thinking about usb wifi adapter, and i did buyed netgear n600 usb wifi adapter (without antenna) and it works for facebook or else, but gets laggy on youtube sometimes but sometimes dont, and sometimes it disconnects itself from router, or i do get slow speeds, when brother's laptop was fine. My friend said that laptop has wifi antenna over the screen. Then later i i found people in forums saying that neatgear is crap, or that usb wifi adapter is crap for gaming, but they dont have others or usb adapters with antenna in local "currys pc world" store, so i got confused. I also found people saying in forums that pci-e wifi card work good for them, but then others do say that pci-e cards are bad and do not work for them, that usb wifi adapter with antenna is better, because you can place it whenever you want with usb cable extender.But then again i found informatio that usb wifi adapters tends to overheat and that causes the problems witch of them i mentioned before.So i would like to ask witch to buy usb wifi adapter ( now with antenna) or pci-e wifi card? and also what manufacturer is better "d-link" , "tp-link" , or "asus"? i was looking for this one http://www.asus.com/Networking/PCEN15/ because 60% liked it of the 100, and the comments in newegg was good for it, but not every.
One thing forgot to mention that router doesnt have antenna sticking out of it, what is somehow strange for me.
