With this case does it come with a premade ideal fan setup?
Valkyrieneos
452
With open fan slots available and the fan controller having 3pin and 4pin connectors what would be the ideal fan setup for this case?
https://www.scan.co.uk/products/be-quiet!-dark-base-pro-900-silver-full-tower-computer-chassis-e-atx-to-mitx-with-window-3x-140mm-si
Would it be ideal to purchase this fan to add to the case and if yes how many and the 3 pin or 4 pin version of this fan.
https://www.scan.co.uk/products/140mm-be-quiet!-silent-wings-3-7-blade-inaudible-airflow-fan-1000rpm-595cfm-155db-fluid-dynamic-3-pi
That's a nice case. And pretty expensive too. :)
Anyway - the case comes with 3x 140mm fans included.
You have to test your system under full load to determine, if default fan setup is sufficient.
My guess is, if you're not using double GPU setup with extra power hungry CPU (like 220W AMD FX), then it should be enough.
