wl-130g PCI wireless card
frank
1,590
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
One question.
I do not need the wireless card supplied with my A8V.
My friend wants to have it. Does this card work in a PC without a Asus
motherboard?
Frank
G
Guest
Guest
"Frank" <schmidt@bth.de> wrote in message
news:414b1df6$0$189$9b622d9e@news.freenet.de...
> One question.
> motherboard?
> Frank
If this is the one that goes into the special asus slot then the answer is
no..
You could probably sell it on ebay.
frank
1,590
I´m asking this because the card cannot be found anywhere on the net and the
manual says you nee a asus board
frank
1,590
> no..
And what is the special asus slot? It is a normal PCI card. In the manual it
says remove the bracket on the pci slot you INTEND to use. It says nothing
about put it in slot 1 2 or three.
It is not a small AMR or what card, normal PCI
G
Guest
Guest
>>no..
On certain ASUS motherboards, there is a AMR-like interface, which is
used along with a specific ASUS brand card/external antenna, permitting
you to not only access a WiFi network, but act as an AP for others.
You can't use it in other motherboards, and you can't use PCI slot 5 on
the motherboards that have it if you are using the proprietary card.
Paul
Splendid
Mar 30, 2004
5,267
In article <7sG2d.436952$M95.233881@pd7tw1no>, Philip Callan
<callanca@shaw.ca> wrote:
> >>no..
manual it
There is a picture here. It looks like a PCI edge card.
http://www.cdrinfo.com/Sections/Articles/Specific.asp?ArticleHeadline=Asus+A8V+motherboard+preview&Series=0
Uses one of the Ralinktech chipsets. The MAC chip RT2560F has
PCI and Cardbus options.
http://www.ralinktech.com/prod-2.htm
Slap it into a PCI slot and try it.
Paul
G
Guest
Guest
news:414b27a0$0$13040$9b622d9e@news.freenet.de...
is
> > no..
it
I'd say give it to ur pal and let him try it then.. :)
I dont know any of their version numbers.. but if it goes into a pci slot
(and if you can use any slot) then I would assue (bad thing sometimes) that
it's safe to go into any slot, granted it might not work, but it shoudl be
safe.
G
Guest
Guest
>>>>no..
> manual it
> Paul
Thats not the same as the WiFI slot in my P4C800-E, its a weird connector.
Similar threads
