My current config can barely run modern games at all low settings at 60 fps but when I look up similar systems they run all settings on high or ultra and get the frames I get on very low please help
I'm guessing the RAM or CPU. Do you know what your ram is (DDR3 or DDR4) and I would recommend upgrading to 16GB of RAM if you can. As for your processor, it is decently dated and that could also be the problem. Here is a CPU that I would recommend as a pretty standard budget CPU https://www.newegg.com/Product/Prod...0g&cm_re=ryzen_5_2400g-_-19-113-480-_-Product
Good Luck
Good Luck
