Wondering if this card will work with my system
The card will work with your computer, the only possible problem is the power supply; you need to check if it has a pcie 6pin connector to power the card
I have some type of 6 pin connector, not sure if it's pcie or how to tell if it is though.
I'm looking to put some money into this PC for sure. Just need a slight upgrade in the GPU department for now. This 7570 isn't holding up very well. I'm hoping the gtx 950 will be a decent upgrade for a year or so.
