ok here is what i purchased...
[PCPartPicker part list](http://pcpartpicker.com/p/2k3W0) / [Price breakdown by merchant](http://pcpartpicker.com/p/2k3W0/by_merchant/) / [Benchmarks](http://pcpartpicker.com/p/2k3W0/benchmarks/)
Type|Item|Price
**CPU** | [Intel Core i5-4670K 3.4GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54670k) | $239.99 @ Newegg
**Motherboard** | [Asus Z87-A ATX LGA1150 Motherboard](http://pcpartpicker.com/part/asus-motherboard-z87a) | $119.99 @ Newegg
**Memory** | [Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/corsair-memory-cmz4gx3m1a1600c9b) | $49.99 @ Newegg
**Storage** | [Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003) | $64.99 @ Newegg
**Video Card** | [Asus GeForce GTX 650 Ti 2GB Video Card](http://pcpartpicker.com/part/asus-video-card-gtx650tioc2gd5) | $140.66 @ Newegg
**Case** | [Rosewill ARMOR-EVO ATX Full Tower Case](http://pcpartpicker.com/part/rosewill-case-armorevo) | $94.98 @ Newegg
**Power Supply** | [Rosewill Hive 750W 80+ Bronze Certified Semi-Modular ATX Power Supply](http://pcpartpicker.com/part/rosewill-power-supply-hive750) | $92.98 @ Newegg
**Optical Drive** | [Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-drw24b1stblkbas) | $16.99 @ Newegg
**Operating System** | [Microsoft Windows 8.1 - OEM (64-bit)](http://pcpartpicker.com/part/microsoft-os-wn700615) | $99.99 @ Newegg
| | **Total**
| Prices include shipping, taxes, and discounts when available. | $920.56
| Generated by PCPartPicker 2013-12-14 04:37 EST-0500 |
i have it put together and running (typing this out on it right now)
right now i'm ordering a fan controller and card reader but have a little money left over (due to holiday pay i forgot i was going to get before the graphics card purchase) and want to know what if any coolers can fit in this case. i know it says it can fit a h100i but do i need a 100 dollar cooler when right now the most i would do is just let intel turbo take over. i have done some temp monitoring with stock heat sink prime 95 15 min blind test with intel turbo on it reached 82,81,81,76 at their highest and avged out at 78,77,78,74 over all. and with intel boost turned off it was lower 70's with 70 being the avg temp on the same test for the same amount of time. i guess what i'm getting at is can i tell now if i have a good chip which i would then invest the 100 dollars into a good cooler for or do i have a less then good chip that would only be worth protecting with a better air cooler and if so what air coolers would fit in this case that has no data (even in 4 video and editorial reviews of it) on the distance from chip to the side or the size of heat sink that it can hold.)
any information would be taken with gratitude. Thank you for your time.
Type|Item|Price
| | **Total**
