Won't connect to monitor after critical process error
allison_5
Commendable
Aug 12, 2016
My computer crashed after I plugged in a USB drive. It's a custom build that's been perfect until after I unplugged the drive. My tower seems to turn on fine but it refuses to connect to my monitor so I can't access anything. After I unplugged the drive, Windows 10 said "Critical process error" and shut itself off after a few seconds.
Hello allison_5
Can you please check if you can Get to Safe Mode? If yes, you can right-click the Start button, go to Device Manager and try to repair or update the graphics driver.
If that doesn't work, uninstall the graphics driver, restart the PC with the standard driver, and then re-install the graphics driver to resolve the issue.
Good Luck!!
Hello allison_5
Good Luck!!
