Won't load CS???
dewood
16
Well I replaced Vista 64 bit with Windows 7 64 bit and I can say I am happy with this except for 1 thing!
When I start-up Steam and try to play Counter-Strike 1.6 all I get is the darn background, I cannot see the options like New Game, Find Servers, Friends, Options. When I hover over them with my mouse I hear the clicks so I know they are there and I can connect to a server via console (~) but still, I can't see anything but the 1.6 background.
Source works fine though :heink:
Any ideas?
Steam apparently has a lot of problems with 7:
http://search.sevenforums.com/results.aspx?k=Steam
I found some potential solutions on the Seven Forums -
Courtesy of user AnXa:
Which he got from: http://chris123nt.com/2009/01/18/sqm-client-causing-crashing-in-windows-7/
Sollution is that you will download Winrar from RarLab and then extract the SteamInstall.msi into some folder, like C:\Program Files\Valve\Steam\ and then rename steam.exe1 into steam.exe and run it.
I tried older steam installers just to find out that those install ok but don't run at all.
For some reason Microsoft Install Service is bugging in Windows 7 about some programs. I thinks related to region and language settings but I am not sure.
There...
wll i am a ATI user... and yap.. the CS dont work in win7 64bits.. the OpenGL drivers are poor in win7 64 bits but.. if u use win7 a 32bit work amazing... and CS:source is a game based in DX9 not in openGL for this reason CS:S run normaly =)
There is also built in MSI Extrator in Windows which you can try like this:
In command prompt:
msiexec /a c:\temp\steaminstall.msi /qb TARGETDIR=c:\temp\steam\
but it caused msi to crash here leaving external program as only option.
I managed to find a fix for Windows Installer problems (aka. problems with .msi files).
1. Delete the string values (Except for (Default)) in HKLM\Software\Microsoft\SQMClient\Windows\DisabledSessions
2. Start gpedit.msc
3. Expand Computer Configuration, expand Administrative Templates, expand System, expand Internet Communication Management, and then click Internet Communication settings.
4. In the details pane, double-click Turn off Windows Customer Experience Improvement Program, and then click Enabled.
Courtesy of user Shamitzu:
An issue with the Customer Experience Improvement Program (CEIP) client in Windows 7 beta is causing Explorer and some MSI-based installers to stop working properly.
To solve this problem, follow these steps:
  1. ■Click the Start button
    , click All Programs, and then click Accessories.
    ■Right-click Command Prompt, and then click Run as administrator.
    In the User Account Control window, verify that Program name is Windows Command Processor, and then click Yes.
    ■In the Administrator: Command Prompt window, type or paste the following text at the prompt:
    reg delete HKLM\SOFTWARE\Microsoft\SQMClient\Windows\DisabledSessions /va /f
    ■Press Enter to install the solution.
    ■If "The operation completed successfully" displays, close the Administrator: Command Prompt window to complete this procedure. If "ERROR: Access is denied" displays, repeat this procedure from the top, making sure you clicked Run as Administrator in step two.
[/B]
I had this same issue, not with build 7000 but with build 7068. I fixed it by turning off my second monitor. It didn't matter whether I had SLI enabled or not, but as soon as CS-Source only had one monitor to deal with it worked perfectly. Hope this helps.
