Won't power on - P5N32-E SLI blinking green light
Kollin_
I turned off my computer and when I went to turn it back on it wouldn't power on.
The light on the motherboard is blinking green, if I remember correctly it used to be a solid green light.
I have tried removing nearly every component in my computer, but it still won't power on.
Any advice would be most welcomed. Thanks.
I don't have any other memory or a power supply to test with. I tried testing with just a single stick of ram in (total of 4). I removed the cmos battery for about 10 seconds then put it back in, but no change.
I shutdown the pc and then turned it back on, I'm not sure what caused this.
