Won't send signal
Jose_113
4
I have a gigabyte GeForce 750 to with a Msi bazooka b250 m motherboard with a 750 watt supply power. there is no signal output but If take off the gpu the system displays the boot menu. Do I buy another gpu? Thanks for the help
Awesome! Glad it is woorking!
I'am also a noob.
PS: Can you select my answer as best? Won't do much, but make me feel a little better :)
Try sticking it in the GPU card rather than the motherboard if u want signal with GPU installed.
Tell me how that went pls.
Edit: also make sure that the gpu card is getting enough power. If it has slots that could be filled by plugs coming out of your power supply, please do fil them (and make sure they fit easly, if you force them, you may get polarity wrong)
bro I'm a beginner and this was my first pc built and let me tell you I have been buying new cards and motherboards for it to work. Thanks man you made my day thanks a lot.
