Workstation Build, 3D Modeling/Rendering
MXS_21
Commendable
Apr 17, 2016
Hello All,
Wanted to get some advice on a build, primary focus is a workstation for rendering, modeling and design. Work as a Production Designer and am heavily getting into modeling and rendering interior/exterior spaces via 3DS and Keyshot, but am primarily using Sketch Up(with Podium-essentially a Keyshot Extension). I have completely tapped out my Macbook Pro with rendering capability and am looking to build a professional grade workstation after graduating in June since I’ll be getting hired with a company and need to get on my “A-Game”.
I don’t need to make a machine that is excessively expensive(high end for the sake of being high end) but want one that I will not have to keep upgrading constantly, will do what I want when I need it to, is upgradeable, and be well above bottom line capability for said usage but not stupidly excessive.
I will say that I have been out of the loop for a while in regards to PC as I’ve been using MacBook Pros(work/personal) for the past 8 years but am switching to a PC workstation for obvious reasons. Have read through a number of threads on here and done some research but would still like to make a thread and get some specific advice, I’ll fill in what I have read about that may fit my needs but hope to get some assistance.
Key Features Wanted: Speed, Accuracy, Reliability.
Programs:
Currently Using and use primarily: Adobe CC (Photoshop, Illustrator, Lightroom), Autodesk(3DS Max, AutoCAD), Keyshot, Sketch Up.
Want to start using: V-Ray, Rhino, Z-Brush
Approximate Purchase Date: June 2016
Budget Range: $2,000 (Ideal) $2,500 (If need be)
-Do not include monitor in above budget.
System Usage from Most to Least Important: Rendering, Modeling, 3D Drafting, Painting(Photoshop), 2D Drafting.
Parts Preferences: Best for selected applications and pro grade use.
Overclocking: Maybe?
Are you buying a monitor: Yes, already have a Wacom 27HD(what a life changer) but would like a monitor to go with it as a secondary screen, and one that is more accurate for viewing completed renders.
Your Monitor Resolution:
Wacom 27QHD-
QHD 2560 x 1440
Additional Comments: Quiet, not concerned about flashy looks but don't just want a plain black box, something tasteful. Smaller the better but not absolutely necessary.
Why Are You Upgrading: Cant run anything on my Macbook Pro, trying to get professional and do it right the first time.
Questions:
GPU vs. CPU for stated applications
Fan vs. Water Cooling
Best Operating System for stated programs.
Help fill in the blanks:
http://pcpartpicker.com/user/MXS_21/saved/sshWGX
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor ($554 @ PC Parts Picker)
Cooling: *Advise*
Motherboard: ASUS x-99A ATX LGA2011-3 Motherboard ($228 @ Newegg)
GPU: Nvidia? *Advise*
Memory/RAM: 64gb Advise*
SSD: Samsung 950 PRO 256GB M.2-2280 SSD
HDD: (3x) 3TB Seagate
Video Card: *Advise*
Case: *Advise*
Power Supply: *Advise*
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($12.99 @ Newegg) ?
Ask away with any questions you may have.
Thanks,
Max
Don't use i7. More cores are better for rendering. Water cooling performs about the same as air coolers, unless you pay extra for some good AIO cooler or custom-made systems, which costs a lot of money. And frankly, that money should go into a better processor and motherboard. Finally, any OS is fine, provided that you have the Pro version.
CPU: Intel Xeon E5-2620 V3 2.4GHz 6-Core Processor ($399.99 @ SuperBiiz)
CPU Cooler: Intel BXRTS2011AC CPU Cooler ($19.99 @ SuperBiiz)
CPU Cooler: Intel BXRTS2011AC CPU Cooler ($19.99 @ SuperBiiz)...
For RAM I think 64GB is probably enough, However if you want 128 could be used. For storage I use animation software a lot and know that storage is important. Use either a RAID 5 Or RAID 10 array of at least 3 drives to safeguard against failure. I use 3 3TB seagate drives. And a separate SSD to boot from. For the video card, For your purpose you should probably go Nvidia. What is your choice is would you prefer one GREAT Gpu or a few good ones using SLI. Good luck with your build.
Thanks for the advice Nathan, I have updated the build to include (1) Samsung SSD to boot from and (3x) 3TB Seagates. I'm going to do some research into SLI for the multiple/one great GPU option.
Great! I hope it works well to your needs.
Motherboard: Asus Z10PE-D8 WS SSI EEB Dual-CPU LGA2011-3 Motherboard ($548.99 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) Registered DDR4-2133 Memory ($104.99 @ Adorama)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($86.88 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.77 @ OutletPC)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card ($443.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($84.99 @ Newegg)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply ($109.99 @ NCIX US)
Operating System: Microsoft Windows 10 Pro OEM (64-bit) ($124.75 @ OutletPC)
Total: $2480.19
Generated by PCPartPicker 2016-04-17 22:24 EDT-0400
Thanks for your input, I have this list saved and am going to do the build in June. Many, Many Thanks!
