Workstation Build for Work
QuinnTheOnly
50
I'm looking to build a 4K video editing machine for my work and I was wondering if there is anything anyone would recommend differently than what I have in my Newegg cart. (Below)
Thanks ahead of time for suggestions.
I suggest you do a bit of research on the requirements of the software you are using.
For example, the video editing I do at home is processor intensive, but doesn't need a big GPU - it edits and plays perfectly even with only onboard graphics.
Many CAD workstations which do require professional 3D graphics use Quadro GPU, not gaming GPU.
Liquid cooling on a work machine? Are you sure this is more reliable than a fan and heatsink?
We use the Adobe CS6 Suite. This machine is strictly built for editing 4K video. I have personally ran Corsair closed loop systems for years without any interruptions.
400GB PCI SSD for Rendering and Scratch disk
250GB SATA SSD for Boot Drive
2TB HDD for Storage
I have replaced the 980 ti with a Titan X
It's for my department, not my money. lol Thanks for the help!
Latest posts
