Workstation Build Help
linotriples
Hi, i have a budget of $2200, and i need a workstation to work with 3rendering, video editing and to connect to a digital canvas to draw on photoshop and illustrator.
This are the build i have in mind, but i dont know much about motherboard choice, SPU, and case size.
https://pcpartpicker.com/user/Linojose/saved/GvXRGX
i took this one from someone else build and i remove some part because it was too much for me.
https://pcpartpicker.com/user/Linojose/saved/2VMCyc
and this is the one i made myself
By only having 1 DIMM per socket, you are giving up 3/4 of the memory bandwidth on those CPUs. 4DIMMs per socket for maximum performance.
For $800 in CPU costs you can probably get a single Threadripper or i9 that will have higher clock speed than the Xeons.
Latest posts
