Question Workstation minimum specs, recommended, and max specs?
UKTone
153
6
18,695
I want to learn all programs, what would be some min, rec, and max requirements for a workstation for rendering, adobe programs, etc.
When it comes to graphics design, animation, rendering, and CAD, then this is one of the few areas where AMD beats Intel hands down.
Intel cpu cores are good, but are limited in number. For a similar amount of money you can get a lot more AMD cores and threads. For those applications which make use of them then this is where the advantage in going AMD is as the efficiencies add up.
For example Photoshop will currently use every AMD core you have for rendering. So if you have 16 AMD cores rather than 8 intel ones you are on a winner.
Reactions: UKTone
16GB recommended and 32GB optimal RAM for high workloads inside those apps. Future proof as well if you go with DDR5.
A SSD is also recommended, although you can get away with a HDD.
Reactions: UKTone
