http://pcpartpicker.com/p/2vLDw is my build minus that mobo, i used this one instead. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131989&clickid=WY91wTX8CweXQ96VDLQO8Ta%3AUkT1-FQvNzdh0I0&iradid=97618&ircid=2106&irpid=79301&nm_mc=AFC-IR&cm_mmc=AFC-IR-_-na-_-na-_-na
got 1 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
and 3 of http://www.newegg.com/Product/Product.aspx?Item=N82E16835103077
is my build the fan placement is 2 140MM fans on the front for intake, 1 140MM fan on the top ( possibly 1 of the 120MM fans aswell for outtake and a 120MM fan on the back for outtake. Should i get fans for the side of my case to blow onto the graphics card? or will what i have planned be good enough to not overheat the gpu?
