Worried about temps and cooling
Snyper1010
13
As you may have noticed from me popping up in pretty much every forum section, I have a new PC. However I am not exactly a tech genius and I am worried about the temperatures that my CPU is running at, especially as it has been overclocked. I would appreciate it if someone who understands all the temp jargon could help me work out if my machine is overheating or not.
CPU - i7-6800k
Cooler - Kraken X31 120mm Closed Loop Liquid Cooler
Motherboard - X99-A II
Core voltage during load - 0.96v (I think, using OCCT)
Core speed if overclocked - 4Ghz
Temperature software - OCCT(?)
Load testing software - OCCT(?)
Load & idle Core temperatures - Idle all 6 cores sat about 38-40 degrees c. Underload OCCT cut the test as the cores reached 86 degrees c
Ambient temperature - Haven't a clue...
I'm not really fussed with taking it further any time soon. I am really just trying to find out what temp this processor can safely work at.
I considered taking the limiter off OCCT and checking what temperature the processor actually goes to under stress, I don't want to end up doing it damage though.
