Hi guys.. wondering if I should replace my five year old "Thermaltake Toughpower Grand RGB 850w Fully Modular Power Supply 80 Plus Gold Certified + Riing 14 RGB Fan " power supply due to an unexpected shutdown in combination with one other problem (keyboard no longer retaining "memory" of whether or not I clicked on "number lock on" after the PC is turned on again like it used to) or if I'm just overreacting.
My desktop PC which has lots of cooling power to the point where other people have, correctly, commented "Dude that's way too many fans 😛 " on this forum (two 140 mm fans in front, one 140 mm fan on the top, one 140 mm fan in the back, fairly decent sized PC case, decent CPU cooler and reported temps of 35 degrees for the CPU and 28 degrees C motherboard, 42 degrees temp graphics card, 33 to 34 degree temp for the not SSD two 8 TB drives) did the whole unexpected shutdown thing today.. I followed the advice in this thread
far as creating a sleep study report and got this rather dismaying message
"System Power State: Abnormal Shutdown
START TIME DURATION STATE ENTRY REASON EXIT REASON % CAPACITY REMAINING AT START
26 2023-07-3013:27:25 0:00:00 Abnormal Shutdown Unknown Unknown -
OS State Data
Data obtained from the Event Viewer Logger."
I'd honestly prefer to just wait and see if more problems pop up before replacing the power supply .. on the other hand afraid of damaging the (somewhat new, this past year) recently installed CPU/RAM/MB
Here's the hardware and specs on my PC in addition to the power supply mentioned above
AMD Ryzen™ 7 5700X 8-Core, 16-Thread Unlocked Desktop Processor
(paired with "Thermalright Peerless Assassin 120 SE CPU Air Cooler, Dual Tower 6 Heat Pipe"
Asus TUF Gaming B550-PLUS AMD Chipset Socket AM4 ATX Motherboard
Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200 (PC4-25600) C16 1.35VDesktop Memory - Black, 2 count
Phanteks Pro M Tempered Glass Case, Black, PH-ES515PTG_BK
Thanks so much to anyone who reads this and replies
Create Sleep Study Report in Windows 10
Windows 10 comes with a nice feature called 'Sleep Study report'. It is available on devices which support the Modern Standby/Instant Go (S0 state).
winaero.com
OS State Data
