Would a 7950 run on my 450w Power supply?
GAMER_1
126
Can a 7950 run on my Silverstone SFX Gold rated 450w power supply? I have 37A and it supports continuous 450w power output. It has dual 6-pin and a single 8-pin PCI-E connection.
If it can't, can the 270x run on 450w?
http://www.guru3d.com/articles_pages/his_radeon_hd_7950_review,8.html
Here is Guru3D's power supply recommendation:
Radeon HD 7950 - On your average system the card requires you to have a 500 Watt power supply unit.
Radeon HD 7950 Crossfire - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina.
http://www.guru3d.com/articles_pages/msi_radeon_r9_270x_gaming_review,8.html
This is Guru3D's generic power supply recommendation for the R7 and R9 series:
AMD R7 260X - On your average system the card requires you to have a 450 Watt power supply unit.
AMD...
AMD R7 260X Crossfire - On your average system the cards require you to have a 650 Watt power supply unit as minimum.
AMD R9 270X - On your average system the card requires you to have a 500 Watt power supply unit.
AMD R9 270X Crossfire - On your average system the cards require you to have a 700 Watt power supply unit as minimum.
AMD R9 280X - On your average system the card requires you to have a 550 Watt power supply unit.
AMD R9 280X Crossfire - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
It's a bit tight. Building new, I certainly wouldn't pick a 450, but if it was there I'd give it a go.... just take it easy and no OC ofc.
