Would a 8-pin fit in a 6-pin slot?
Aug 5, 2018
6
Hi, i just bougth two 8-pin PCI-e cables from cablemod because i thougth all 1080ti’s had 2x8-pins. But then i realized that the refrence cards go 1 8-pin and 1 6 pin, and i can get a really good deal on one (not yet bougth it).
So i was wondering if a 8 pin cable would fit in a 6-pin slot, with 2 pins just hanging there?
Oh, it's an extension that extends the length of the cable. I have a couple of those for a GPU mining rig. The 8-pin is a solid piece and will not fit on a 6-pin connector.
Why did you have to use an extension? Is is a mining rig?
