Would a dead CMOS battery cause a system not boot?
abdu3000
81
I have an eMachines system which is about 8 years old and hasn't been used for a while. When I hit the power switch, the HDD led comes on for a split second then nothing happens.
I don't have tools or anything to test the PSU and the battery. A red LED on the motherboard is on when power is connected to the PSU.
I know a dead battery shouldn't stop a machine from booting but are there some systems which won't boot if the battery is dead?
In all likelihood, you have a bad PSU. Next most likely source of problem is a dead motherboard.
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboarding
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%. If you have a white wire (many modern PSU's do not), it should be -5 volts.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
spacecomputer
I just fixed a non-booting COMPAQ PRESARIO 5441 by replacing the totally dead CMOS back-up battery. The client reported having to set the time each time he booted, the system finally would not boot.
jita1
Yes, a dead battery could indeed be the culprit. I had the same issue with my PC about a year ago. I hadn't used it in awhile. The light would come on and the fan would spin for a second and then nothing. I replaced the system battery and it booted right up, good as new.
RamdomPCGeek67
6
I have never had that happen with any of my computers, but I think it can cause a computer not to start. I think it just depends on the computer and the bios. You will have to reset the time and settings in the bios. Hope this helps! :)
Abbeysaurus
5
Hey guys, I'm having boot issues with my PC too. I too had the issue of having to always re-set the time everytime I power up the machine. And finally my PC refused to boot up. But my mother board does power up... All components are moving, but nothing on my screen. Also getting qcode 63 on my mobo LED. I tried ram, CPU and other troubleshooting and came to the conclusion it's the motherboard that's faulty.
Do you think it could be the little battery after all?
