Question Would a Dualsense work well with a Bluetooth 4.0 dongle on pc?
Pupq1
Commendable
Jun 6, 2019
88
So I'm buying a Dualsense to use on pc (gonna get a ps5 in the future) and I found a cheap bluetooth 4.0 dongle for $5 (my pc doesn't have bt). I know that's pretty old for bluetooth but would it still work decently? I don't care about the wire that much, even though wireless is a nice bonus, but I'm kinda worried about it affecting the battery if I play with it plugged in all the time.
I just wanna know if you can make it work with the dongle with something like DS4Windows and if yes, then how good would be the latency/stability (I'm never more than 3 ft far from my pc). Should I spend an extra $20 on a BT 5.0 dongle, or is this good enough? Or should I just use it wired? Thanks
