A AceMovie Commendable Dec 14, 2016 50 0 1,640 Dec 23, 2016 #1 Would a GTX 1060 work with a 240watt PSU? I already have a GTX 1050 and a Dell OptiPlex 390. I am wondering if I can use a 1060 fine if I add an adaptor to a sata power cable.
Solution delaro Dec 23, 2016 No even the stock card will draw up to 120W that is a heavy push for a 240W. I wouldn't go anything lower than a 350W. Here is the 400W TFX upgrade. It's not as good in quality as the 240W unfortunately. 400W Power Supply Upgrade for Dell Optiplex 390 790 990 7GC81 6MVJH $45 http://www.ebay.com/itm/like/291616153876?lpid=82&chn=ps&ul_noapp=true TFX supplies above 350W are not easy to find as it isn't exactly a popular upgrade size. Here is the bare minimum but with a better warranty. SeaSonic SS-350TGM Retail 350W TFX12V $50 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151115
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,669 1,808 159,590 Dec 23, 2016 #2 No it will not ....Sorry. Upvote 0 Downvote
A AceMovie Commendable Dec 14, 2016 50 0 1,640 Dec 23, 2016 #3 No it will not ....Sorry. Would it work if I upgraded to 350watt and used an adapter? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,669 1,808 159,590 Dec 23, 2016 #4 I would get a decent 450w for a 1060 , the 240w is even too light for the 1050 , it will cause PSU failure eventually. Upvote 0 Downvote
delaro Judicious Ambassador Aug 23, 2011 4,427 251 33,740 Dec 23, 2016 Solution #5 No even the stock card will draw up to 120W that is a heavy push for a 240W. I wouldn't go anything lower than a 350W. Here is the 400W TFX upgrade. It's not as good in quality as the 240W unfortunately. 400W Power Supply Upgrade for Dell Optiplex 390 790 990 7GC81 6MVJH $45 http://www.ebay.com/itm/like/291616153876?lpid=82&chn=ps&ul_noapp=true TFX supplies above 350W are not easy to find as it isn't exactly a popular upgrade size. Here is the bare minimum but with a better warranty. SeaSonic SS-350TGM Retail 350W TFX12V $50 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151115 Upvote 0 Downvote Solution
