I am looking into buying a Radeon HD 6950 AX6950 because I can get one for cheaper than normal. I am wondering if it is compatible with the ASUS m11bb-bo7 pc. The specs:
Windows 8.1 x64bit
350 watt PSU,
amd a10 6700 APU
8gb DDR3 ram
ASUS f2a55-m Motherboard
Toshiba DTO1ACA100 1tb
as well as an aditional HDD I mounted, which is a Western Digital with 1tb storage aswell.
TL;DR: Is the GPU compatible and is the PSU sufficient?
If not please tell me which non expensive (but good enough to make a good performance increase) GPU will fit a 350 watt psu
Also I am not planning on Overclocking
Windows 8.1 x64bit
350 watt PSU,
amd a10 6700 APU
8gb DDR3 ram
